creating my facade // ideal route
4 REPLIES 4
338 Views, 4 Replies
Revit beginner here. Thus far I have successfully complete my building I'm now experimenting for the facade I'm trying to achieve. I need some direction on how I can recreate this https://www.dezeen.com/2017/02/03/dominique-coulon-associes-media-third-place-library-thionville-fra...
4 REPLIES 4
The link here says link not found and goes to the home page, kindly check the link
loboarch
I think this is supposed to be the link:
Here is my take on this kind of condition. It is not exactly the same because i was projecting the tops and bottoms of the curved walls to a reference plane so they are flat.
Now that I look closer at the image the windows do not project to a flat plane. if that was needed, the only way to do it would be with the conceptual massing tools.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
The link is not found
in reply to: loboarch
Thanks for the demonstration really appreciate the assistance, as this is one of the last features I'm working on I'm experimenting with what ever will portray my idea best. Even if flat Its worth me trying, could you brief this reference plane process used so I can give it a go. also I planned on exploring the conceptual mass tool, would you say it is effective to achieve what I'm after?
