creating master keynote schedule with division headers
jledgewood409
Message 1 of 8
jledgewood409
i am creating a master keynote schedule that will show all keynotes in project. i would like to have each csi/master format division to show up as a header e.g.
DIVISION 01
  01 00 03 ABCDEFG
  01 00 04 HIJKLMNO
Replies (7)
Message 2 of 8
Message 3 of 8
jledgewood409
what I am looking to do is to include each division name as a header in the keynote schedule. similar to a sheet index where you can create headers for each discipline i.e. Architectural, Structural, Mechanical.
Message 4 of 8
So you ignored the part of the article about how to create headers and sub-headers?
00 Architecture         Architecture Specs
00
Message 5 of 8
jledgewood409
I understand that you can have categories and sub-categories in your text file. I would like those categories to show up in revit as a header for each division. if have a master keynote schedule  on a sheet I would like each division (csi/master format) to show up/read as a header.
I did not see in the article where this is shown how to do?
Message 6 of 8
For each line item you have to specify where that line item will appear under.
So I clicked post too early...
00       Architecture
00 01 00    Header    00
00 01 01     Sub-header 00 01 00
00 01 01.1  line item    00 01 01
Definitely suggest the add-in Keynote Manager from Revolution Design to make it a lot easier to create your keynote file.
Message 7 of 8
So what I am showing only relates to how a keynote can be selected...
You cannot create a keynote legend that shows the different categories.  You will have to be creative and create multiple keynote legends with dummy text for the header category.
Message 8 of 8
I'm having the same difficulties.  My company is using the Keynote Manager by Revolution Design.  It's a wonderful tool and helps emmensly while working on projects with inexperienced people who do not understand how to modify a Keynote file correctly.  Regardless, How do I get my Master Condoc List to display with the Divisions and headers?  The Keynote file is managed by the add-in so and when you click on an item to change the keynote, the typical Revit Keynote window appears with all of the correct divisions and sub-headers.  Please see the images below for examples of how the Keynotes look in the Keynote Manager, Revit Keynote Dialogue, and the actual text file created by the Keynote Manager.
