Revit Worksharing not able to use Create New Local File
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
RobDraw
465 Aufrufe, 7 Antworten
We are trying to use both a network license and stand alone licenses for a workshared project. It is not allowing the stand alone licenses to create a local file.
Is possible to do this?
< Edited Content for better support. >
Rob
7 ANTWORTEN 7
Nachricht 2 von 8
Mark.Lancaster
als Antwort auf: RobDraw
@RobDraw
Stand alone in respect to a standalone perpetual license or in the terms of a single user subscription license?
@DarrenP or @ToddRogers-WPM Thoughts?
Mark Lancaster
Nachricht 3 von 8
RobDraw
als Antwort auf: Mark.Lancaster
All that I know at this point is that they are non-network licenses of which we have three. There is only one network license.
Rob
Nachricht 4 von 8
DarrenP
are you using Bim 360 design sharing or revit server sharing?
is there an error message?
 it could be anyone of these: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
DarrenP
Nachricht 5 von 8
RobDraw
als Antwort auf: DarrenP
Neither.
All users are on the same LAN.
The network license is new. This office is just starting to use Revit with this project. I've set-up lots of projects both cloud and LAN with both either all stand alone or network licenses but never a mix.
As a test from a stand alone license, I opened the project that was set-up with the network license and made a new central out of it. The workstation with the network license cannot create a new local, the option is grayed out and vice versa. I'm thinking that they don't play well together.
Rob
Nachricht 6 von 8
DarrenP
you can try number 3 here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
this is not being caused by licensing it could be a mapping issuse
DarrenP
Nachricht 7 von 8
RobDraw
That does indeed describe exactly what I am seeing. Unfortunately, I don't know how to check the mapping, so I can't verify it at this point. Thanks for pointing me in that direction.
Edit: It looks like the mapping is different and we don't have full time IT support. Time to put another feather in my cap.
Rob
Nachricht 8 von 8
RobDraw
Thanks again @DarrenP. It turns out that the computer that I was testing with is mapped differently than the other computers.
Rob
