Creating a label that can count the number of times it has been used
Sahay_R
Mentor Mentor
Sahay_R
Is it possible to create a label that can count and show the number of times that it has been placed in a project? I am trying to create a tag for egress doors. If it could generate the egress door number that would be a great time saver. Thank you!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
If you identify the egress doors with any available field such as Comments then you can create a door schedule and filter by that field, to count the Egress only doors.
Or, select the Egress tag, right click, Select All Instances in Project, and look at the count.
Sahay_R
I would also like the tag to show the number - you know, DOOR 1 and so on on the tag itself.
Would modifying the Mark be a solution? Our Mark has been modified to read A100 and so on. Could I create a duplicate Mark with just numbers?
Rina Sahay
Yes you can include a number in the Tag. But it is a number you manually enter for each egress door, not the automatic counting number like you mentioned.
