I'm trying to create a custom rail/balustrade system in Revit which looks a little something like this:
I can get something close:
But not quite... The logic seems to be that I need two balustrade types with their own spacing requirements but for the life of me I can't figure it out. Please help pivot my thinking. @RDAOU, I'm looking at you...
Thank you.
Solved by barthbradley. Go to Solution.
Is this the problem? Wrapping around corners?
Create a Custom Post that has both a Post and Baluster Geometry in it.
There are two elements - the triangle fold and the straight baluster.
I can't work out how to get the straight baluster to show behind the folded baluster. Meaning, I don't know how to implement both elements to create the rail I want.
I noticed you've done it in the post I marked as a solution.
Is your solution to create a custom baluster which has both in already?
Thanks.
There are several ways:
