creating 3D box in ceiling space
victorwongiam
Message 1 of 8
victorwongiam
I wish to build a 3D box in ceiling space to demonstrate to other trades that our fixtures need this space...but I can't find the Extrusion button!? The Create tab is missing?? I am just scrambling to draw cheap detail lines for nowbut I would really like to learn!
Replies (7)
Message 2 of 8
Are you using Revit LT?
Message 3 of 8
victorwongiam
REVIT 2016 as far as I know. is there a short cut?
Message 4 of 8
Ribbon > Architecture > Component > Model In-place
But, you should have create a parametric family it so that you can easily change size for different ceiling objects.  Best is you can have the consultant build it in their fixture families.
Message 5 of 8
victorwongiam
Right. Kind of rock in a hard place moment as it was modeled but other trades blast through our material kind of story. So was scrambling. Appreciate the advice ToanDN!
Message 6 of 8
chrisplyler
I would place symbolic lines right into the fixture family, on both the front/back plane and the left/right plane, representing the required clear space. I would assign those symbolic lines to a new, unique Subcategory so that they can be turned on/off as desired within a project view.
Message 7 of 8
Architecture Tab....Component....Model In Place.
And I can already tell you are going to have space issues in that section...unless  you don't have any mechanical at all.
Edit....5 minutes too late... 😉
Message 8 of 8
chrisplyler
Nah, he could still stuff 6" flex duct through open joists, only crushing it down to 3" or so. No problem. Smiley Surprised
