Cannot adding triangle head level to proprieties
Message 1 of 12
Hello!
I am starting Revit 2014 Lt and try to add triangle head level from the Families>Annotations to the 8mm head.
I am loading Family>Libraries>US Metric>Annotations>M_Level Head-Triangle; click Open
Go back to Proprieties, click on the drop menu upper window Level 8mm Head and I cannot find Level Head Triangle and I have only the bubble 8mm Head style.
What am I doing wrong?
Thank you for your help guys!
Michel
Replies (11)
Message 2 of 12
You only loaded the symbol, which is the first step.  Now edit a Level type and change it to use that symbol.
Message 3 of 12
Sahay_R
Do you see it in the Families list in your Browser? Click on the + sign to see a list of Families in your Project.
Try inserting the symbol. You can drag the symbol right off the Browser, or Annotate >> Symbol
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 12
I did as the following:
Highlight my Bubble 8 mm Head
Go to proprieties but do not find Triangle head but only 8mm Head in the drop menu
Message 5 of 12
Open the Triangle Head family file and load it in your Project again, or just drag and drop the RFA file onto your Project Browser.  It may not have been loaded the first time.
Message 6 of 12
I try again and again.
Sorry but can you be more specific when you said "Project Browser". Thank you
Message 7 of 12
Drag and drop the file like I show below:
Message 8 of 12
chrisplyler
You keep looking in the Type Selector for a triangular Level type that doesn't exist yet. You've only loaded the symbol, but you haven't created a Level Type that uses it.
Select an existing Level or activate the Level tool in the ribbon, then in the Properties Pallet click Edit Type. In the dialog that pops up, click Duplicate, type in a new type name that's appropriate for a triangle head Level, and look for your triangle symbol family in the Symbol parameter. Click Okay.
Now you will find your new Level Type in the Type Selector of the Properties window.
Message 9 of 12
Okay it is helpful: yes my name head triangle appear in the drop menu, but
when I select my level and click on no visual change....I still with my initial bubble
Message 10 of 12
when I select my level and click on no visual change....I still with my initial bubble.
Message 11 of 12
See screencast.
Message 12 of 12
Thanks so MUCH!!!
I was not checking the graphic visibility and select in the drop menu my new name triangle. This step was missing.
Thank you very much , very helpful Toan DN!!
