create your own shared parameters with formula
mzmaso90
Message 1 of 18
mzmaso90
Just to keep on knowing how to start using shared parameters. At first sight, It seems to me that I need to create a text files, better imported on Excel before and trace the parameters on a row using standard or personal column styles format to give to Revit the format to convert your parameters formula in automatic style import. How to set up this files, and what do you literaly you advice to don't create errors? I found for example this File from HVAC company, but I am not sure if using it and add one or more parameters or create a new one with similar rules.
Any advice? Best regards
Lorenzo
Replies (17)
Message 2 of 18
It's a lot easier to create shared parameters from within the Project or Family environment.
Help | About Setting Up Shared Parameter Files | Autodesk
Message 3 of 18
regarding your HVAC Family:  export their parameters to your Shared Parameter Text File.
Help | Export Shared Parameters to a Shared Parameter File | Autodesk
Message 4 of 18
mzmaso90
Yes but let's say for example, I want to add parameters to spaces that I actually don't find in Revit by default. Would be feasible anyway?
Message 5 of 18
You're talking Project Parameters now.
Help | Create or Modify Project Parameters | Autodesk
Message 6 of 18
There's a video at this Link:
Help | Project Parameters | Autodesk
Message 7 of 18
Alfredo_Medina
Shared parameters file should not be created editing a .txt file nor Excel file. Instead, use Revit's dialog boxes to create and edit your shared parameters file. Begin by Manage > Shared Parameters > Create > [name the new file] > Create a group > Create a parameter.
Message 8 of 18
ralphdenhaan
FYI: shared-parameters/
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 9 of 18
heichan88
hello, when I want to export a parameter to a shared parameter file, exactly follow the above steps, once it works (appears in the txt file), but now not working any more, please advice , thanks
Message 10 of 18
Have you set the shared parameters text file?
Message 11 of 18
heichan88
yes man times,
Message 12 of 18
@heichan88 wrote:
yes man times,
Yeah but did you point to that file from Revit > Manage > Shared parameters?
Message 13 of 18
heichan88
yes sir, i tried all the ways (seems like that)
Message 14 of 18
heichan88
I create a blank new one txt file, and only one parameter can be exported, others cannot, no idea what restricted
Message 15 of 18
Maybe it is already in the txt file.
Message 16 of 18
heichan88
i create a blank new one, and one parameter can be exported, other cannot
there is no other txt file in the whole RVT folders, i tried delete old parameter and input formula again, also tried export in another family, .....also tried a blank parameter without formula.... none working....
is it a software version problem also? this is a direct function....
Message 17 of 18
What I meant was the parameter was already in the txt file.
Message 18 of 18
heichan88
hello @ToanDN
no, there is no parameter in the txt file, i now created a blank new txt file, nothing inside, please see the screenshot
