Create table in layout listing visible referenced files in a view.
miguel_villegasDSJAB
Hello.
I have been searching deep and can not manage to find even if this wish is possible.
We work estensively with referenced dwg and ifc files, and we need to produce layouts in which these files overlay our own views.
The point is that when a layout is produced, there must be a clear documented overview of which external references are visible in the document we are producing.
Is there a way to do it? I am working in german, and though I am fluent in english, the search for the propert tool/concept eludes me a bit.
Any help will be very much appreciated.
RDAOU
@miguel_villegasDSJAB
In order not to repeat what you may have already tried and/or read/heard elsewhere, did you try to ask in the Revit German forum and got no answer?
In short, there is no direct tool or schedule type which does that per view/per sheet. You can do it using Dynamo though
No, I came directly here, as I believe the amount of Revit experts is bigger here and if I get a solution I can "translate" it.
Thanks for the answer though.
