export problem
export problem
tcholadze_niko
export problem
tcholadze_niko
I have problem after exporting title block. why sink looks like low quality object and pipes sometimes cross conected object lines. help to fix this. its last steps to finish project 😔image.png
vitorbortoncello
looks like it need just linework
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
arq_42
Haven't you asked this before?
https://forums.autodesk.com/t5/revit-architecture-forum/graghical-problem/td-p/13412495
You need to set the line weights in Manage/Additional/Line Weights
and then work with them in both Manage/Object Styles and VG.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
tcholadze_niko
Yes I already asked but I still have this problem. thats why I asked again
Manage/Additional/Line Weights > Yes I set all of them but it is not fixed
but Now I have Another importent problem
The Architecture that I made and MEP file is two different Revit file.
Architecture is imported in MEP and there is new problem. In architectural file walls has overrides and its black. but in mep it looks like white. In VG I changed revit links by host view also linked view and also custom but overrides doesnt appear.
how to fix this ? 😓
