Model Checker - Stair Runs Parameters
jhallarsisatias
jhallarsisatias
I would like to know if it's possible for the BIM Interoperability - Model Checker to extract these data from 'Stair Runs' I would like to extract the data from these such as Nosing Length and Structural Depth but when I use 'Stairs' as Category, I am not getting the result that I wanted probably because these parameters are not really under the 'Stairs' category. I tried using the "Family: Monolithic Run" and "Type: Monolithic Run" to no avail. I am setting rules for the Model Checker to yield "Fails" if someone set values to these parameters that are below the standards.
JasonKunkel
It looks like the Category for the Run only is OST_StairsRun. Change your filter to that and see if the parameters are stored there.
It looks like you are starting to dig into some more advanced checks. Have you installed RevitLookup? I highly recommend getting that add-in when working with Model Checker. It lets you peek "under the hood" to get actual category names, built in parameter names, what is a property vs a parameter, what data type the parameter is stored in, etc.
Releases · lookup-foundation/RevitLookup
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
jhallarsisatias
Thanks Jason, it worked! Yeah, will look at Revit Lookup.
