Create glowing buildings
12 REPLIES 12
Message 1 of 13
1446 Views, 12 Replies
I have a site model with components in and I would like to make the components glow in a night time render. I have set their material to self illuminate and played around with all the setting but once I render it in the cloud, the brightness is always overpowering so you cannot see any of the component. I just want a light glow from the components that also lights up the surroundings. Any ideas of achieving this?
12 REPLIES 12
Message 2 of 13
dzanta
try changing the date, time, azimuth and altitude so the sun is low...
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 13
in reply to: dzanta
I want it to be pretty much completely dark with just the glow of the building illuminating the other surrounding buildings
Message 4 of 13
L.Maas
Maybe it is an issue with the cloud renderer. There are always some differences between the different renderers. Could be that some functions are not supported well in the coud renderer. Have you tried it locally (with both renderers)?
Louis
Please mention Revit version, especially when uploading Revit files.
Message 5 of 13
I have noticed that the outcome various when cloud rendering. It renders fine locally but the overall quality is way better in cloud.
Message 6 of 13
loboarch
This problem sounded kind of interresting to me, so I gave it a try.  My model is kind quick and dirty so excuse the roughness. I found pretty much the same issue with render in the cloud.  The light becomes way to intense.  Here are the 3 images I got.  1 is the base model, 2nd is local rendering using the Raytracer engine in Revit, and the 3rd is rendering in the cloud set to "final".  Besides that there are no changes between the renders.
So based on these results I would say the cloud render is doing somethign strange.  Not sure exactly what or how to control?
P.S. The building just to the south of the "glowing" buillding in my model is the Autodesk office in Manchester NH.  the glowing building would be in our parking lot.  Smiley Happy
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 7 of 13
in reply to: loboarch
thanks for investigating, dont know if theres anyone to contact for the cloud rendering services or something like that. Guess it is a photoshop job
Message 8 of 13
loboarch
I will send this thread along to the cloud render team to take a look at. I even have a dataset for them to work with and test.
Jeff Hanson
Revit Help |
Message 9 of 13
anavaidya
Hi @Anonymous,
Thanks for posting your images. I have got a sample file from @loboarch which the Rendering team can use to debug the problem. I'll keep you updated.
For future, you can post rendering questions here: http://forums.autodesk.com/t5/a360-rendering-general/bd-p/2060
Aradhana Vaidya
Customer Success Engineer, Rendering & Visualization
Message 10 of 13
in reply to: anavaidya
any news? I would like to have this problem solved by friday so I can use it in my presentation in uni
Message 11 of 13
anavaidya
Hi @Anonymous,
This may not be fixed immediately. But you can adjust the exposure of the image and see if you get the desired result. Select your image thumbnail in My Renderings and click "Adjust Exposure". Let me know if this works.
Aradhana Vaidya
Message 12 of 13
Thank you so much! with the correct illuminance setting then adjusting the exposure and midtones once rendered online I got exactly what I wanted.
Message 13 of 13
David_W_Koch
Nice image.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Forma Design Contest
Technology Administrators
