Create extrusion in section view
mmostafaHKPP5
mmostafaHKPP5
I simply want to create model in place. the best and easiest way is to draw an extrusion in a section view. I'm having hard time doing this. Can you please help?
Alfredo_Medina
You need to set a workplane (Architecture > Set > select a workplane) which could be a grid, a named reference plane, or the face of an object. Then you can draw the extrusion in the section view, perpendicular to the workplane.
syman2000
If you have gridline facing perpendicular to your section view, you can use grid as your reference. First you go to set and pick a plane. If you don't have gridline, then use reference plane.
