Point.project doesn’t work the same after update
Joos_T
Message 1 of 1
Joos_T
I’ve made a dynamo program to see if a point is in a certain area.
I only need the point inside, not those that are on the lines.
Before i’ve updated Revit it worked just fine with point.project. After the update it doesn’t filter out the points outside te lines.
Thank you in advance.
See attached files
Replies (0)
