Create Custom Chevron Brick Pattern
please kindly provide a chevron brick pattern as a size of ( 200x 1200x2mm) in a format of *.pat file.
its really helpful for me ongoing live project.....
Accepted solutions (4)
aRcHiTeCt.JM
... hi @Anonymous
... go here https://pattycake.io/pat
@Pattycake_Kyle
... you can draw any .pat that you need
... try that pattern as a size of ( 200x 1200x2mm)
... it is pretty easy
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Registration code required please kindly provide detail how to signup and getting registration code.
aRcHiTeCt.JM
... hi @Anonymous
.... just follow instructions
.... they will be happy to assist you
... here are some other treads about .pat files from this pattycake
https://forums.autodesk.com/t5/revit-architecture-forum/tile-pattern-chevron-2-quot-x-9-quot/m-p/8817278
https://forums.autodesk.com/t5/revit-architecture-forum/bespoke-brick-pattern/m-p/8868153
... or you can try this other one: https://www.hatchkit.com.au/
aRcHiTeCt.JM
REVIT EXPERT ELITE
hugha
Try this:
; Written by HatchKit Professional
; HatchKit (c)1990-2019 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2019/09/27
;-Time : 21:37:40
;-HatchKit Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=MM
*Chevron1200x200+2
;%TYPE=MODEL
44.977879,0,0,2414.82470,10.103899,1200,-46894.572127
135.02212,-2,0,2414.82470,-10.103899,1200,-46894.572127
44.977879,0,282.84,2414.82470,10.103899,1200,-46894.572127
135.02212,-2,282.84,2414.82470,-10.103899,1200,-46894.572127
90,0,0,0,-1701.05627,282.84,-2.8311396
90,848.53,848.53,0,-1701.05627,282.84,-2.8311396
90,-2,0,0,-1701.05627,282.84,-2.8311396
90,850.53,848.53,0,-1701.05627,282.84,-2.8311396
as discussed elsewhere, representing 2mm mortar may be overfine modelling and this could be sufficient:
;-Date : 2019/09/27
;-Time : 21:48:42
;%VERSION=3.0
;%UNITS=MM
*Chevron1200x200+0
;%TYPE=MODEL
45,0,0,200,200,1200,-1200
135,0,0,200,-200,1200,-1200
90,0,0,0,848.5281
hth,
Hugh Adamson
Pattycake_Kyle
Thanks @aRcHiTeCt.JM for helping out!
@Anonymous, they pretty much covered it. We are opening up our beta to everyone now, so please use code: sprinkles19 to sign up.
For the chevron you requested, I believe this is what you need: https://pattycake.io/pat/6G296A718mB
With the calculator templates, you can easily change sizes from here as you reiterate designs and there are also options for herringbone and other standard patterns. Just make sure you select MM for your units on the left when using Revit Model Patterns.
Note that our current beta has not yet been updated with a herringbone that can do variable widths. We will release that in our next big Version 01 update. If this is something you need, feel free to reach us in any of the ways above and I can help directly 🙂 Happy pattycaking!
This is the process to make the above pattern:
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
really its very helpful for me without spacing but i want with spacing of 2mm
