Does anyone know how to hide these floor lines so in 3D mode you won't see them?
it looks like your floor is extending through the wall and your lower level walls are set to attach to the underside of the the slab. try selecting the lower level wall and see it the detach button is available in the contect panel on the modify tab.
do they show when you press the Reveal Hidden Elements toggle in the view window
Is the workset that the sections are on visible?
Is the sections category on the annotations tab of Visibility Graphics turned on?
Sorry wrong post
You can edit your floor and pick the external side it core face (or use Pick Wall with extend to core checked). After that you can join the floor and the wall.
If you don’t worry about the detail, you can just join the floor and wall, then switch join order.
you can't hide that lines. you can use invisible lines to hide in 3D per view. thanks
If You are working on unfinished model then you can't hide floor line in 3d view
you wrote
how do u make them invisible?
just go modify > linework (see icon) > , select the line style - invisible lines > select your lines in your 3D view to hide just double click. thanks
