Create blend from 2 cross sections but the result is not as expected
danise_natalia
danise_natalia
I am trying to use blend to create 2 cross sections, here is the base
And here is the top cross section
And 3D solid result is as below :
Point 1 should meet point 3, and point 2 should meet point 4, however in this result point 1 & 2 meet point 3 and is not as expected, why does this happen?
Anyone please need your help.
Many thanks,
Danise
Split the two vertical lines of base profile so the base has the same number of points as the top.
_Vijay
Instead of blend try with sweep blend.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
