Hii Geniuses,
Other than usual delete option, is there any options to delete Existing ceiling floor!!.
Kindly solve me ASAP.
Gelöst! Gehe zur Lösung
Gelöst von RobDraw. Gehe zur Lösung
Why do you need another way?
What's wrong with the "usual" way?
Thank you for your reply,
at first we creating our own company template, as our requirements we don't need of structural floorplans and ceiling floor plans,
so only im asking is there any way to delete existing ceiling plans permanently, and acts as project template.
@Mohamed_Arshad wrote:
so only im asking is there any way to delete existing ceiling plans.
Why didn't you say that in the first place?
You can select them in the project browser and delete them with the delete key or right click/delete.
They can also be deleted from a view schedule.
Thank You!!!
Sorry!!,
Now i understand, I use Schedules to delete existing ceiling plans i will be better than using delete key.
FWIW: If this is typical for you (e.g. deleting Ceiling Plan Views) you can create an RTE (Template) that does not have any Ceiling Plan Views in it upon starting a New Project. Simply Open a New Project using your Default Template that includes Ceilings Plan Views, delete the Ceiling Plan Views and then press File: Save As: Template.
