- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys,
Im new to Revit, so just getting to grips with it. I have drawn architectural walls which I need to swap out for basement retaining walls.
The walls need a base of 600mm wide, and a top of 300mm, with one side therefore being vertical (inside) and the other angled to complete the profile (external side). I have attached an autocad file of what I hoping to achieve.
Does anyone know how to create this type of wall in Revit? Additionally, when snapping two walls at 90 degrees, I'd need the walls to recognise that the two walls are not entirely vertical elements; the inner sides will snap at 90 degrees, since both verticals are located (pink lines in attachment), but the external faces, since the walls are sloped, will leave a gap. I would need the top faces to be extended by 300mm to join at the top, and the same at the bottom. In addition to creating the vertical element between the top and bottom. (yellow lines in attachment)
I'd appreciate any help with this.
Elliot
