CREATE A SHEET WITH SAME NAME AND NUMBER IN REVIT
HEY GUYS, Here is a trick to add a sheet with same name and number
>SHEETS >NEW SHEET >RENAME >RIGHT CLICK IN NUMBER BOX >INSERT UNICODE CONTROL CHARACTERS >SELECT EITHER "LRM OR RLM"
"IF U PREFER LRM SELECT LRM ONLY FOR OTHER SHEETS DUPLICATION ALSO
IF U PREFER RLM SELECT RLM ONLY FOR OTHER SHEETS DUPLICATION ALSO"
THANKS & REGARDS,
TEJA ROYAL KATTA.
kimberly_fuhrman-jones
Hi, @Anonymous ,
I'm just going through some older posts and think this one may be better served in the Revit forums as it is more of a "tip" than an Idea for an enhancement. I would like to move this post to the forums if you agree.
Thank you!
Kimberly
Kimberly Fuhrman-Jones
Revit Community Manager
vstkattaAT2W5
Community Visitor
Community Visitor
Hi @kimberly_fuhrman-jones
u can go ahead, and post it in forums
ashahan
Observer
Observer
I have encountered issues when establishing print sets. Specifically, sheets with the same name - but include unicode characters to trick the system - do not show up on the print set list when trying to create sets for multiple bid packages. Do you have a work around for this?
Thanks.
RSomppi
Do you mean sheets with the same number? Duplicate names are allowed.
