Create a drawing view of ONLY a model group
cbt990
cbt990
My project consists of repeated dwelling units, each its own group, which are arrayed throughout the building. How can I create a drawing view of one group in isolation?
Revit is amazing
kadmonkee
duplicate a floor plan view
adjust the crop region so it is blank
insert each group into the space and align them as you like
you can do 1 group per view or multiple groups in the view
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Duplicate a view > Select a group > Temporary Isolate > Isolate Element > Temporary Isolate (again) > Apply Isolate to View.
kadmonkee
well that would be much quicker thanks
thank you
Is this for a Legend of sorts?  If so, another approach would be to create a PRE-Existing (e.g. a Phase that starts before the Project Construction Phases begin).  Place Instance(s) of the Model Group(s) (from Project Browser) in this PRE-Existing Phase (a.k.a. Legend View Phase).  Set Phase Demolished of Group Elements to the name of the Phase that begins your Construction. This is so the PRE-Existing Phase Group Elements won't be counted in Construction Phase MTOs and QTOs.  Basically, they are "isolated".  Now, a copy of the Group(s) exist in a Phase which any View can show "in isolation" from the Construction Phases.
cbt990
Interesting idea, I remember watching a Paul Aubin video where he suggested using pre-construction phases for a similar purpose of creating type libraries that can be laid out to show all different types simultaneously.
Revit is amazing
If you want to do it that way, place the group in a Post-Construction phase and set the view's phase filter to Show New Only.
