Crazy lines in 3D and plan views
mrattanBWNAN
mrattanBWNAN
Hi everyone,
In Revit 2022, there are these weird lines all over the place in both 3D and plan views. It is limiting how many components I can select. It doesn't look like this when the visual style is set to wireframe, but appears in all the other styles.
What I can find online similar to this is about the graphics card, but it is a brand new computer with all the specs for the Autodesk suite.
Thanks for the help and insight!
syman2000
Is there a CAD link placed in the file? I encounter this issue before but it was fix when I restart the computer. It was related to updating graphic card.
ennujozlagam
try to switch off from options use hardware acceleration and update your graphics card driver to the latest and see if helps.
mrattanBWNAN
Turning off hardware acceleration did the trick. Thank you!!
