I changed a site plan from 1/4" to 3/16" and following this, the fill patterns in my filled regions are not visible. I can still select the filled regions, none of the properties have changed. Does anyone know why this is?
Revit wants is for you to increase the scale or spacing between the individual lines of the Filled Region pattern - then it will switch back to black, as it should be.
Is the fill region model or drafting pattern?
