Crazy dimensions when exporting to CAD
Hi, i have the following problema when exporting a file from Revit to autocad. The dimensions go crazy when i move or copy the plan, it still have the same properties and everything remains the same, but they dont look the same.
ennujozlagam
create a new dimension style with your setting and dim update and see if helps. thanks
