Dear community, for research purposes I had to make a spherical structure (screenshot attached), but I came across following issue:
Being on level 1 I set a space, and on this level it is bounded just fine. same goes for any level.
But the space doesnt wollow the curvature, keeping straight shape in vertical direction.
How do I make it follow the curvature?
Regards
The level that hosts your walls has a Computation Height parameter which defines where the room area/volume is evaluated. You can raise the computation height but it may have to be too high for other rooms in the design. Technically the habitable portion of such a room is more meaningful since it is hard to "live" in the curved portion of the room, above the floor.
Steve Stafford
If you can create the curved shell as roofs then the room/space will recognize them.
