is there any way to make a counting tag, so each time a place this tag, it start counting, and increasing 1 by 1
Create a property line for each lot and a property line schedule then you can add Count. If you tag them sequently from the start then they should be numbered in sequence, but if you already tagged them and want to renumber them, you have to do it manually or download pyRevit and run renumbering tool to do it for you.
Toan Nguyen
