COUNT totals with KEYNOTES workaround
Hello world.
Is there any way I can count keynoted elements?
I NEED* to use keynotes for tagging appliances and having the elements totals is also necessary.
I am looking to avoid inserting the spec values (ex: A1) in two parameters manually. (For example I would need to insert the value A1 in keynote # parameter and Model (for example) parameter to get a schedule with totals (count).
I wonder if Dynamo can make this task easier. Any clue?
Thank you world
*keynote schedule will appear in every sheet and i want only the used tags to show up. so this is a must.
FarhanUddinShaikh
hi, have you tried to edit type of particular element with their appropriate property and existence of family as well.
