Rendering Problem in Revit and 3ds Max
wcbcad
wcbcad
I am trying to produce a decent rendering in Revit for a simple beach house.  I am using RPC objects in the model.
I have the scene set up and did a rendering in Revit with “best” selected.  The rendering keeps coming out with a green tint to the lighter materials.  I first thought is a monitor setting.  But, my client has commented on the green tint.
After much unsuccessful tweaking and experimenting with Revit to get the green out, I stepped into the realm of rendering in 3ds Max.  Now, I have issues with the RPC objects not rendering in the “ART” renderer or the sun lighting is not correct in the renderers that support RPC.
Can anyone help me with good setting in Revit or 3ds Max for a good Photo Rendering using RPC objects without a hint of green or lighting issues?
Needless to say, this is not going to be a profitable venture with this rendering.  But, I need to get this figured out for future projects.
Viveka_CD
Hi @wcbcad
Can you post a screenshot of the rendering and the settings?
Wich version of Revit and 3dsMax do you use?
wcbcad
I am using Revit and 3ds 2018 with all current updates.
constantin.stroescu
Rendering in 3d Max allows using of other instruments beside RPC .You can find a lot of scripts (some of them free) for  3d Max as Tree Generators , Grass Generators, and so on
For example, I use for trees Laubwerk :  http://www.laubwerk.com/  - They have a few freebies : http://www.laubwerk.com/store/plants-kit-freebie/
You can see below some example of renderings made in 3d Max using Laubwerk and a grass /plants generator......
Constantin Stroescu
Viveka_CD
Hi @wcbcad
Can you share a file to help troubleshoot further?
Viveka_CD
Hi @wcbcad
I'm checking back to see if there is any progress on your rendering.
Please see Best Practices: Rendering
For questions regarding rendering in 3dsMax please post to the 3dsmax forum
