Couldn't able to export the IFC file.
maulik.patelXHLDE
maulik.patelXHLDE
I am using the Revit 2020 product and I want to export the IFC file of my Revit model. When I try to export the IFC it took so long to export, I understand it may be because of more elements in the Revit file, but at the end of the export I got the error "There is a fatal error occurred during the export, the export is now aborted.” After that, I couldn't export the IFC file in Revit.
rxi.gg
Good morning, have a look in case it can help you
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-sh...
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
