I have the student version of Revit 2021 and have installed the first part but am unable to select the core content and than click install. I have attached a photo below as to what I see, there is no error message I am just unable to click anything.
Core content is a separate download and installation.
Core content is ALWAYS installed. You can’t select to not install it and don’t need to select it to have it installed. Additional content can be downloaded if needed.
I downloaded the UK files and extracted them but then still had this same issue when I went to try install again
The issue in the image at the top of this thread where it says the core content is not installed
just ignore that. download the content library and install.
Where do i download the content library because i cannot find it, unless it is the downloads from the link in the first reply which i have tried multiple times.
Has anyone found a solution to resolve this problem post installation i still cannot access the programme and have extracted all additional family libraries
Hi... Make sure Your internet is connected while installing the Revit Setup
The setup will download required Core Content From the autodesk server
If not connected to internet while installing it wont
U can download it from autodesk
Thanks for the reply , I've tried uninstalling all components of revit 2021 and downloading them again still no success, Autodesk Revit 2021 Content | Revit Products 2021 | Autodesk Knowledge Network i tried to download the additional components from this link is there any other way i could get them, any links is appreciated it
Jeff Hanson is correct. This image does not indicate a problem and this is the intended workflow for the Revit 2021 installer. Revit Core Content is a mandatory part of the Revit 2021 installer and therefore there isn't an option to disable its installation.
The intent of Revit Core Content is to provide users the basic content files needed to launch Revit without warnings about missing content files. Additional content files can be downloaded from this page: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/downloads/content/autodes....
I have the same issue. Core content not installed. Do you have any solution for that? I don't know what to do?
