Copy/Paste Alignment Issue (CTRL C, CTRL V)
Kev_D
Kev_D
I am experiencing a very weird issue that I just have never seen before. It is happening with the whole team on the same project.
When an element is selected, and CTRL C is used to copy, and CTRL V used to paste where you paste it at 90deg a certain distance away from the existing, the element is slightly off alignment. It does not happen with the Copy command, only the copy/paste to/from clipboard.
The example in the image is a detail component. CTRL C to copy, down at 50mm @ 90deg, pasted with CTRL V, and you can see the 0.96 difference.
I have tried this multiple times with several different components on several views.
Work Plane related?
Kev_D
Nothing to do with workplane. it even happens when you simply draw a detail line and copy/paste it, it ends up being misaligned as well.
RobDraw
Why are you using OS commands that don't give you the desired result instead of native Revit commands which give you much more control?
Rob
Lachlan-JWP
Have these views been rotated or had scope boxes applied?
