Copy-monitor Structural Framing
6 REPLIES 6
2843 Views, 6 Replies
Is there a way to copy-monitor Structural Framing from Revit Link (Structural model)?
Tags (1)
6 REPLIES 6
lanl
Hi johnkensantos,
You can check the link below for the supported types of element:
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-46735245-3836-4470-99C0-320397718BE6
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
Hello @Anonymous
Blinding the link is not an option?
Nope, I want to monitor any changes on the framing. Seems like its not supported. Ill post it on Ideas instead.
yassinemestiri
any answer ? this still a big issue for BIM manager work, to control changes !!
dear autodesk gods (seen before on another forum) : please answer quickly !!
No, change. Copy monitor only works on columns (Levels, Grids, Walls and Floors), not framing. Framing is not usually modeled twice in separate models. Columns are often modeled early on, conceptually and then the structural engineer takes over.  Thus columns are part of C/M but not framing. I'm not aware of it changing any time soon.
Steve Stafford
petrlanik
in reply to: SteveKStafford
There is still a lot of work to be done by Autodesk on this. On contrary, framing in lot of cases needs to be modeled twice both for arch and struc world.
For same reason the loadbearing parts of walls and floors should be modeled separately, as there is no good way displaying only loadbearing parts of sandwich floor or wall in structural model.
