copy/monitor issues
copy/monitor issues
cbt990
copy/monitor issues
cbt990
I attempted to use copy/monitor to transfer items between projects including walls and doors. Unfortunately none of the doors transferred over, only wall openings. Now I am getting warnings about elements which have been copied over and then deleted from the model after being replaced with doors (in the case of door openings) and warnings about elements which have been copied over from the other model and deleted from there (in the case of walls).
I attempted to resolve the warning at startup that Link Needs Coordination Review by using coordination review. I screwed up and deleted a bunch of stuff so I quit and reopened. Here is what i see now:
Is there a way for me to just "ignore" all of these?
Revit is amazing
cbt990
ok. What can be done about all of the coordination alerts?
Revit is amazing
RobDraw
What are the available options? Pick the one that works best for you.
Rob
