Copy/Monitor IFC - Copier/Controler IFC
Hi all, AUTODESK,
The copy and monitor Tools (copier/controler in french) is fantastic. However when working with other softwares like ARCHICAD, there is no way to copy and monitor objects from an IFC.
Is there a way Autodesk can develop a plugin to do that? that doesn't seem complicated with the API.
Damien
Luiscko
For the moment there is no way to do that i hope for the new version you can Copy/Monitoring IFC element but i think so it could be a utopy because is no a native element and this is the principal reason why you can do right now.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
