Hi All.
This is my first time of posting so hope someone has a solution.
We have a floor plan view which has a site location plan (OS Map) linked and (whilst I don't advocate this) solid hatch to indicate the buildings.
On a sheet view this floor plan is then overlaid with another floor plan cropped to the new site shape and positioned over the OS Map floor plan which gives site context.
The issue we have is that the hatching for the OS link will not print to PDF or direct to a printer.
Has anyone experienced this problem and found a solution?
Thanks Richard
Hello! You could try changing the hatch from a solid to a very narrow cross hatch instead I've had similar issues before with solid hatches from AutoCAD and that seems to have sorted it.
Graeme
Thanks for your suggestion but unfortunately it didn't work on this occassion
