Copy in Copy/Monitor is copying objects multiple floors down
srobbinsJV25S
srobbinsJV25S
We are trying to copy a diffuser from our Mechanical teams model. When copied with copy/monitor, the diffuser ends up 4 stories below where we started the copy/monitor from. (See attached image) Its been very hard to find solutions with this problem. Please let me know your thoughts.Screenshot 2024-09-11 113059.png
Interesting. Does Coordination Review report it moved?
jay_colcombe
Can you Tab Select the Diffuser in the Linked model and investigate the Level or Reference Level, I have seem some strange processes where they only use one level and offset everything from this?
Also are you floor levels in place comparison with the linked model and its not just being placed on the only level available.
Jay Colcombe
Autodesk Certified Instructor
srobbinsJV25S
It does not. This is immediately after clicking Copy.
srobbinsJV25S
Interestingly, the diffuser in the Mechanical model isnt assigned to a level. 😕
SteveKStafford
If it isn't hosted in their model then most likely it is being placed relative to the work plane of the view you're using C/M in.
Steve Stafford
