Copy Formula Value to the Type Parameter in the Schedule Using Dynamo
amarkonathala
amarkonathala
Can u Tell me How to Copy Formula Value to the Type Parameter in the Schedule Using Dynamo, and the formula I used is..
if(and(Size_H > 101.6 mm, Size_H < 457.2 mm), (Size_H + 76.2 mm), if(and(Size_H > 482.6 mm, Size_H < 711.2 mm), (Size_H + 101.6 mm), if(and(Size_H > 736.6 mm, Size_H < 1016 mm), (Size_H + 127 mm), if(and(Size_H > 1041.4 mm, Size_H < 1371.6 mm), (Size_H + 152.4 mm), if(and(Size_H > 1397 mm, Size_H < 1447.8 mm), (Size_H + 101.6 mm), if(and(Size_H > 1473.2 mm, Size_H < 2133.6 mm), (Size_H + 127 mm), if(and(Size_H > 2159 mm, Size_H < 2895.6 mm), (Size_H + 152.4 mm), Size_H)))))))
#1. How to create this formula in Dynamo
#2. How to copy to the Type Parameter USing Dynamo
_Vijay
please post in dynamo forum.
But I don't think current Revit API allows that.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
woezme
Was you ever able to find a dynamo script or work around to accomplish your task....I'm looking for the same thing...
franciscopossetto
Hey,
I don´t think so. If the value is the same, you could write a formula to get that value, which basically would be copying the result from one field to another.
On your schema, the parameter NominalHeight contains a formula.  Put the following formula on your parameter COBie.Type.NominalHeight:
if(0 = 0, NominalHeight, 2147483647)
As 0 is equal to 0, this expression will be always evaluated as true. Then, the COBie.Type.NominalHeight will always have the same value as NominalHeight
I hope it helps,
Kind regards.
Github:
https://github.com/franpossetto
woezme
So...are you saying I can create Calculated Formula.....and if so...Can I use this formula for system area....
What would that formula be?
Are you referring to Dynamo...or Revit out-of-box calculated formula
