Hi all,
I have made a family consisting of 3 parts. An inner steelplate, a core and a outer steelplate.
The steelplates are in different thickness.
They have to be the same model (0,8mm thickness) but I want to choose a different thickness (like 1 and 2mm) for the steelplates.
So like an option to choose the thickness of the steelplates, that comes back in the schedule lists.
I also want that choose option for materials, so a list of diffent materials that comes back in the schedule.
Thanks in advance!
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Constantin Stroescu
Thanks for the reply.
I have a question left: My model exist of 10 profiles using a sweep. These profiels are the core and are different thickness, but the same material.
If I understand correct: Do I have to make an instance for each combination with the steelsheets, or can I simply "switch" within the family to another thickness of steelsheet?
you have to have different instances only if you use different materials , and then you'll use Yes/No Visibility Parameters....otherwise for different dimensions you'll need no other instances but only Type definitions....
Constantin Stroescu
