Copy and paste windows in the model
I am copy and paste windows from the clipboard to other levels, but I get a message error that said : "instances of 36" x 27" not cutting anything". How can I solve this problem?  Thank you
loboarch
This means you are pasting windows into a position where there is NOT a wall. Make sure there is a host on all the levels you are pasting to so the window has somewhere to go.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
dbroad
when you copy a window to levels, there needs to be a wall in the same location where the window will be.  The message, in essence, is telling you there is no host for the window to be placed into.  There is no need to use the clipboard either.
Architect, Registered NC, VA, SC, & GA.
