Convert or Exporting the existing Revit 2026.3 file to ISM or IFC
sanjida_bd_dhk
sanjida_bd_dhk
Community Visitor
Community Visitor
Hello Dear Community Forum and Experts,
I need your help and support on that. I am working architectural with a revit file 2026.3, now I need to Convert or Exporting the existing Revit 2026.3 file to ISM or IFC that I can open to StaadPro 2025 with iTwin Analytical Synchronizer. I am trying with this from last 2 days and trying with from different ways but I am not able to solving this and come to you for the solutions and I need help on this badly, I couldn't sleep last night because of this trying again and again. I just wanted to export only steel portions from revit file 2026.3 to to StaadPro 2025.
Now I am here for the solutions and I need help on this please.
I am having Installed REVIT 2026.3, StaadPro 2025 and iTwin Analytical Synchronizer for StaadPro Importing.
Below is my revit file in drive that needed to export in IFC or ISM:
https://drive.google.com/drive/folders/16q3ypkKiZgwuajydlYv88nGkuitT3SYH?usp=sharing
Simon_Weel
What I usually do when exporting to IFC is using a 3D view where I isolate the parts to export and in the IFC exporter check the box for option Only export parts visible in view.
_Vijay
Here is a quick video demonstration on how to export IFC from Revit
https://youtu.be/aRBCxOTY1Gk?si=4GGoUFLZ1RBd2CXi
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
sanjida_bd_dhk
Community Visitor
Community Visitor
Actually, I tried so many times but always its seems something wrong again and again.
I don't know and may not able to finding out what's is going wrong with this !!
sanjida_bd_dhk
Community Visitor
Community Visitor
Actually, I tried so many times with this but somehow I wasn't able to export this.
I don't know what's going wrong again and again. And because of the versions of those softwares many senior engineers are not having much experience on that.
So, I am not having any guidance on that. Even though YouTube and online sources also don't have any clear explanations on this matter.
Simon_Weel
When I click the link for Google Drive, it only lists a bitmap?
Simon_Weel
So what goes wrong? As I said, open a 3D view, switch off all categories you don't want to export, click File > Export > IFC. Select a setup, click Modify Setup, select tab Additional Content  and check Export only elements visible in view. Click OK and the export begins. When done check the IFC file in an IFC viewer (there are plenty out there to download) if it's what you want.
