Convert length to angle in adaptive family parameters
I have a reporting length parameter and I want it to influence angle (the longer - the bigger angle you have)
Is it possible to make relationship between length and angle? (the problem is an error "Inconsistent units")
RDAOU
@Anonymous Hi
It should be possible
  1. either using trigonometric relationships  (Sin Cos Tan ...etc
  2. or if you have none, the same way you convert values to intiger in scheduling ie: create a parameter which converts the reporter to a unitless number
Alfredo_Medina
Here's an example. The units for Length are meters. The units for Angle is decimal degree. Therefore, in the forumla, you need to need to eliminate first the length unit (in this example, meters), by dividing the value of Length by 1 meter. Then, you multiply for a value in the desired units (degrees). In this case, I made Angle be two times the value of Length.
