I am making a sofa family and I have 2 different nested cushion seats. After placing first cushion, I assign a family parameter so that the cushion style can be changed. Then I create an array, and assign a label to control number of cushions. I can successfully change between the two loaded cushions and all families in the array updates. As soon as I lock any side of the array to a reference plane, I get a "Constraints are not satisfied" error when switching cushions.
Any idea what the problem is here?
Why would you need to align and lock sides of Array after-the-fact? Constraints are built into the Array/Grouping. Perhaps you can post the family so we can see what you've done.
I need to lock the start/end of aray so it adjusts to the width of the sofa/number of seats. Cushion width is constrained to be Length/# Cushions. If I cant constraint the end of my array, then it wouldn't fit properl as Length or # Cushions changes.
Im trying to post the family, but there's something weird with the website, it won't let me post any attachment.
Ah! I misunderstood. I get what you are trying to do. Need to see the family to see what's going on.
Yeah, posting attachments has been a nightmare lately. Send me the family via email. I'll send my email address to you via PM.
I see the problem and can fix. Can you open a 2018, 2019 or 2020 file? I think you sent me a 2017 which I don't have.
yep, will do. Although Im not sure what you meant by the last comment. Im pretty sure I've been arraying from left to right
