Control The Rotation Of A Sweep
1 ANTWORT 1
Nachricht 1 von 2
1720 Aufrufe, 1 Antwort
Hello, is there anyway to control the rotation of a sweep?
Below for example I have a sweep that starts at the correct angle as it should, then when it turns around a corner to follow another model line it goes off on a 90 degree angle.
thanks
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
There is no control. You need to use some workaround such as using a combination of sweeps, swept blends, blends to control the profile orientation; or use a railing, a fascia, a slab edge, a wall sweep if applicable. What are you trying to model?
