In creating the schedule, there are options, such as: mark; width, height, etc. Is there a way to add an option such as 'room' so that you know that this window belongs in a certain room? Or is there another way?
Yes, in the Fields window for the schedules, check in the drop-down "Select available fields from:".
Whilst in the Schedule view just click on the Fields > Edit button in Properties. Then from the 'Select available fields from:' drop down choose 'From Room' or 'To Room' and select the Room:Name field. This will now show the To/From Room Name in your schedule. thanks
