Contour Lines with dxf file do not display in Revit
I have currently created contour lines and saved it as DWF file. The issue is it displays in the Revit as a straight line instead of a toposurface after I use the Link CAD command. May I know what can I do to solve this?
Best regards,
Joon
ennujozlagam
the file must be dwg? can you post your file so we can check. thanks
Hi Ennu,
The attachment below is the dwg file. Thanks.
Uncheck the box Current view only when you linking the CAD file.
ennujozlagam
The reason why your contour lines become straight lines in 3D view because it was just a 2D line and no value of your X and Y points. See sample of site plan from the surveyor. try to add some value points and see what happen. Thanks
May I know where can I add those values in? Is it adding in CAD or revit?
Thanks.
