Contour lines not appearing under a certain level
tareqathamneh6QW84
tareqathamneh6QW84
contour lines do not appear under the ground floor level for some reason, in all views...
Thanks!
EATREVITPOOPCAD
topo settings probably are set to stop (or start) displaying contours at a certain level
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-M...
The definition of insanity is doing the same thing over and over again and expecting different results
