Constraints are not satisfied - window family
mairh_tsek
mairh_tsek
Hello all,
I want to create a window family.
As you can see in the .rfa file I have created two reference plan , with the first one I want to control the Gap from the wall and with the secont one I want to control the insert of window.
I am trying to 'lock' the detail that I have created in these reference plan, so when I move the reference line to move also the detail.
Sometimes by chance I can do it some others I took the message ' Constraints are not satisfied'.
How Can I do it? What steps I need to follow? It seams that if I just allign the detail in the reference plan, it doesn;t work always..
Thank you!
You have some rouge elements displaced a great distance from the origin in the detail family. I deleted them and the detail seems to work fine in the Host Family now.  See attached revised family
mairh_tsek
Hello @barthbradley ,
Thank you for your notice! I delete them and I advanced a little bit with the family.
But again when I change the width or the insert parameters the profiles don't follow the new value..
I have multiple times align and lock each profile with the reference plans, but when I add a new reference plan or when I make a change always something goes wrong.
Thank you in advance!
