Connecting 2 dieffent stairs
Hi!
I need to connect 2 sets of stairs with the same landing. Each set has different raiser height.
I need to connect them in order to create 1 railing and support system.
Can anyone help?
Thanks!
Amit
It looks like you just need to adjust the offset or start with tread on the above stairs. No?
It is not possible to have different riser heights in one stair.  You netter off with two stairs with overlapping landing, edit the railing paths so that one railing starts where the other ends.
I think your solution will send the wrong information about Revit's capabilities. You can most definitely have two distinct runs in a single flight such as you showed. And you can wrap both with a Railing. Just saying.
Cheers
Cheers
Of course he can have two or more distinct runs.  But what he wants is the runs having different riser heights.
I get that. It's a badly written post. I mean 2 different stair types sharing a common landing - not 2 types in the same sketch.  Regardless, you can still make a contiguous railing, which is what I thought the crux of this thread was about.
