Connect non-orthogonal walls with a column
utech.udara
utech.udara
Hi everyone,
I am trying to model non-orthogonal walls at a junction where Column exist.  I want wall edges to be parallels to column faces. (Please see the image attached.)  How can I solve this?
mposkurlat
Hi, @utech.udara ,
1st Trim/Extend to Corner your walls
then Switch Join Order between the column and the walls
utech.udara
Thank you for your reply. I actually needs to connect as follows.
Is this possible?
RDAOU
@utech.udara
It is possible but the walls you are using in Revit are thicker than the ones you showed in the CAD snapshot
  • Either adjust the walls' layers to match the overall suitable width
  • Or Chnage the dimensions of the Columns
    • then Join Geometry
utech.udara
Thank you very much. It works ! :D. I had to disallow join geometry as shown in your video.
By the way even we try to join with different thickness it works.
Additional thickness continue till joining point. I think this is a better solution once we try to flush walls with plaster to structural columns.
(Right side with join geometry, Left side without)
