I can't get the balusters to connect with the top of the railing. here are my settings, what should I change to fix this? thank you
Solved by barthbradley. Go to Solution.
My guess is that the Spindle Baluster Family is messed up. Post it here.
Here's the custom family file!
Yah, it's not built correctly. You need to cut the top and bottom with Voids. Open an OOTB Baluster to see how it's done.
Got it now, thank you!
